Problem Filling Up Tank
steve04z71
I have a 2004 GMC with a 5.3 v8. I am having a problem filling the gas tank up. When fueling up at a gas station I cannot get gas to go into the tank very fast. I have to fuel up VERY slowly "like 1 gallon takes 3 minutes". I took it to a dealership and they didn't kow what was wrong so I replaced the gas tank with a new one. Unfortunately this did not solve the problem. I know our trucks are equipped with the EVAP system, could this cause this problem??
any ideas?
Yes, there is no vent back up the filler hose, rather the air flows through the evap canister. I would suspect the canister is plugged with dirt. If you are going to replace canister, then get the updated valve from GM and put the vent filter under the hood using 5/8 heater hose.
OK, you have the exact same year/engine GMC truck that I have and I had the EXACT same problem. I am having trouble believing you replaced the entire gas tank without first determining that that was the problem, but I'll let that slide. I'm also troubled that the dealer didn't know what could cause it. Once SparkTech turned me on to the ONLY fuel tank vent path that exists for our trucks, the answer was fairly obvious.
Assuming you have the same problem, it will be a stuck-shut VSV (Vent Solenoid Valve). To verify this, remove the quick-disconnect fitting on the hose that runs between the charcoal canister and the VSV. This is a molded, hard-plastic tube. The VSV is mounted to the plastic gas-tank shield, at the rear of shield (between the gas tank and the differential). The disconnect is at the cannister end of the tube. There are two fingers on a plastic retainer piece that you push up on to remove the retainer, then the disconnect comes apart easily.
Once you get the hose off, leave it off while you try to fill the tank. If it fills normally, viola! Go to the GMC dealer and get a new VSV. They will sell you the kit to relocate the VSV exhaust filter along with a new VSV. They are about $140 :withstupid: , which is just ridiculous IMO. And you can't just leave it off, you will get a nasty EVAP System "Large Leak" engine code.
You can chuck the rest of the kit and just replace the VSV (not recommended) or you can follow the instructions and put the new exhaust filter up by the transmission and run 5/8 heater hose back to the VSV. I did neither. Running heater hose through the frame rail was more than I wanted to do, so I ran the heater hose up to the fuel inlet and tie-wrapped the new VSV filter way up high inside the fender by the fuel filler, facing down so splashes couldn't get to it. I have the hose itself sitting on top of the fuel tank. I have not received any engine codes since I did this fix.
Here is a link to my troubleshooting and fixing efforts: http://www.gm-trucks.com/forums/index.php?showtopic=77906. I hope you find it useful.
FuzzyDriver
I am still having issues putting the filter next to the trans, I run it up beside the master cylinder.
I was concerned that, if I used much hose, the tank wouldn't vent fast enough during filling and the gas would back up in the filler tube and trip off the pump. That's why I elected to keep it as short as reasonable and still get it up high. The only other thing to be careful about, where I put it, is that if there's too much hose up there it could whap around inside the fender when you hit a bump.
I have to agree with you about putting it next to the trans. I evaluated that real close, since that's what the directions said to do, then it was "Naaaah, I don't think so....".
I have put the vent on EVERY truck I have fixed next to the master cylinder, using between 13' to 18" of hose and not 1 has come back, my own included! As for the routing, I send it along with the harness and tie strap it in place.
  • 7 months later...
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 1,165 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
