New Body Style 07-08 Gmc
it so ill try it here. i was tld this past weekend that the body is differnt but the roughly the frame set up is the same. im trying to find an exhaust and a parts(aftermarket access)place said hes put on dozens of exhaust and they are the same fit fot eh older style. anyone know if this is true. im thinking of getting a magnaflow for an extended cab and just cutting it down to fit. any suggestions or has anyone done this for a reg. cab short bed? thanks
I spent 170 on a magnaflow muffler,turndown ,install with welding,don't really need a catback imo,but stylintrucks.com has most of the catbacks for the 07-08
but i'm sure your way could be done
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
