Anyone Installed An E85 Conversion Kit?
Just wondering if anyone has installed an E85 conversion kit? Which kit did you use? Did you like the results?
DOn't bother with ethanol. Take it from a master tech, if you want to drop 30% of your fuel economy and waste money your money on something that is no cost effective. Did you know it cost over $4.00 today to make a gallon of ethanol. Did you know in the process of making ethinal it is extremely polutive. Did you know you can guy ethanol today is because the government is subsidising it. It's shit and I have worked on alot of vehicals that had complaints of the vehicle just doesn't run the same. I test the alcohol content and tell them to call me in two weeks after running strait unleaded. Problem solved. on the upside it does work good to clean you injecters out evaperates water!!! There are some cities now that you cannot even buy ethanol. Unless they start making ethenal out of a weed or a grass you it wil disappear. That is unless you like paying $10 for a loaf of bread and $12 for a lb of hamburger. When a country starts putting our fuel needs in front of the food needs, were in trouble, thanks to our brilliant congressman!!!
Thanks for the reply. Your input goes right along with my feeling on ethanol. It's a pour bandaid for a much greater problem. I'm still curious if anyone did try a conversion kit and what the results were.
    250.3k
    Victorlani
    Victorlani
  • Who's Online   1 Member, 0 Anonymous, 339 Guests (See full list)
