4l60e Problems
My 97 2.2L with 4L60E has some problems.
Good R but no take off from OD or D at all, I can take off from 1 everytime then manually shift to 2 then D as I pick up speed but no OD at any speed, it's just like N when I shift in to OD at any speed. I have to manually shift down if I slow down. Somebody thinks sun gear is broken but R is good and drives ok if I manually shift through gears. Just no OD. Does anyone know what's wrong with it?
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,179 Guests (See full list)
