Will 09 Avalanche Have 6.2 Option?
Can't find this anywhere......
Will the '09 Avalanche have the 6.2L / 6-speed option? (Presuming it will have to be an LTZ).
Thanks, Ben
Nope,They won't have the 6.2,But they will have the 6-spd trans.
Huh, kinda strange, eh? Thks for the info!
Not really too strange,The 6-spd. is pretty much going across the board to replace the 4-spd.
Where as the 6.2 is still going to be pretty limited,just the Denali's/Escalade's (Where its standard) and SLT/LTZ Crew-Cab pickups will offer it as an option.
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 641 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
