06 Silverado Max Fan Speed Inop
My coworkers truck is a basic (not WT) 06 reg cab with manual AC controls. Today after lunch he started the truck and the fan wouldn't come on at all. He restarted the truck and after that the fan worked on every speed except the highest speed (5 on the control). I know Max Fan inop used to be a common problem on GM vehicles but I haven't heard anyone mention this as a common problem on GMT-800 and 900 series vehicles. So what is the likely fix for this problem on the truck I described???
This has become a common issue with the '03-'07 GMT800 trucks,Whatever he does MAKE SURE he replaces the connector,EVEN if it looks OK it might be "crystalized" inside where you can't see it,If it is and he only changes the resistor the resistor will go bad again.
Trust me on this,I've seen many times at the dealership where the tech. changed the resistor and didn't change the connector and the resistor would go bad again within a week or two.
Service Information
2006 Chevrolet Chevy K Silverado - 4WD | Sierra, Silverado (VIN C/K) Service Manual | HVAC | View All Bulletins | Document ID: 1870357
#05-01-38-012C: EI05082 - Loss of Blower Motor Speeds Except for Low Speed or Inoperative (Replace Blower Motor Resistor and Resistor Module Connector) keyword fan - (Nov 2, 2006)
Subject: EI05082 -- Loss of Blower Motor Speeds Except for Low Speed or Inoperative (Replace Blower Motor Resistor and Resistor Module Connector)
Models: 2004-2006 Chevrolet Avalanche, Silverado, Suburban, Tahoe, TrailBlazer, TrailBlazer EXT
2007 Chevrolet Silverado (Classic) Built Prior to September 1, 2006
2004-2006 GMC Envoy, Envoy XL, Sierra, Yukon, Yukon Denali, Yukon XL
2007 GMC Sierra (Classic) Built Prior to September 1, 2006
with HVAC System AC Front, Manual Temp Control (RPO CJ3) or Heater Only (RPO C42)
This bulletin is being revised to clarify the Warranty Information. Please discard Corporate Bulletin Number 05-01-38-012B (Section 01 -- HVAC).
Condition
Some customers may comment that the blower will only work on low speeds or has become inoperative.
Correction
REPLACE THE BLOWER MOTOR RESISTOR AND RESISTOR MODULE CONNECTOR.
Replace the blower motor resistor and module connector using the following procedure:
Remove the blower fuse.
• Fullsize Trucks and Utility Vehicles -- Htr A/C & HVAC 1 fuses
• Midsize Utility Vehicles -- Blower Fuse 35 located in the Underhood Fuse Block
Lower the hush panel or close-out panel enough to gain access to the resistor module connector.
Disconnect the connector from the resistor module.
Remove the tape from the wiring harness to expose the wiring.
Cut the wires back far enough from the connector to eliminate any melted insulation on the wire.
Tip
Use the old connector as a map for splicing the wires for the new connector. Be sure to use the correct crimping tool from the terminal repair kit J 38125. Use only Duraseal splice sleeves. Other splice sleeves may not protect the splice from moisture or provide a good electrical connection.
Install the new connector. Use the yellow splice sleeves provided with the connector.
Install new blower motor resistor.
Reinstall the fuse or connector block. Test the blower motor to make sure all speeds are functional.
Reinstall the hush panel/close-out panel.
Parts Information
Important: **To determine which resistor to use for Fullsize Truck/Utility vehicles, search the parts catalog using the vehicle's VIN**
Part Number
Description
Qty
15862656
Connector - Resistor Blower Motor (includes splice sleeves)
Resistor -- Blower Motor (Fullsize Truck/Utility)
Resistor -- HVAC & A/C (midsize utility vehicles)
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
N9561*
HVAC Module Connector and Resistor - Replace
0.6 hr
*This is a unique labor operation number for bulletin use only. This number will not be published in the Labor Time Guide.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2008 General Motors Corporation. All rights reserved.
    appletrav
    appletrav
  • Who's Online   3 Members, 0 Anonymous, 802 Guests (See full list)
