99 Sub Problems When Starting
Hi, we have a 99 suburban that starts ok, but everytime we start it the lifters make clicking noice the first 15 seconds, unless it ran a few minutes before then it's hardly noticable. it runs very smooth after they stop clicking.
it hasnt been used very much lately, what would be the best way to fix that issue? please help.
