Gms Number - One Additional Available Per Employee
Anyone ready to buy a new truck and in need of a GMS Number, let me know.
Must be used by 8/19/08. Only one available per employee. First come, first served.
Please be absolutely sure that you're going to use it.
Thanks for buying a GM truck!!
Already used. Congrats mteater!
Thank you very much. I was just telling my wife how bummed I was missing the other then I saw your message. Too bad the dealer is closed on Sunday :crackup:
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
