Valve Job or not?
My '76 Suburban has about 90K miles on the original 454.  Doesn't appear to be burning oil, but there is a puff of smoke at startup, telling me that my valve guide seals are leaking.  I am installing a new intake and headers this week, and am considering having the heads done while I'm at it, since I will have all the other stuff off of them anyway.
My question is, will the bottom end and rings wear more quickly after the valve job?  Should I just wait and rebuild the whole engine at once in a few years?  The valve job would be about ? for both heads at a local hot-rod engine building shop.
One more question...should I go ahead and slip in a better cam and a new timing set while I'm there, too?  Again, effects on the bottom end?
Thanks!!
Jeff
At a mere 90k, I'd get a valve job. You probably don't have too much wear on the engine unless it has been abused or seriously neglected.
Contrary to popular belief, a head job will not shorten the life of your bottom end. You just have to realize that the new heads you're running don't make a new motor!
Thanks for the input.  I'm going to call the shop tomorrow and see what they say, and if they can turn the heads around in a couple of days for me.  I figure I can get 50K to 100K more miles from this engine if I keep the fluids changed and don't beat on it.  I pretty much never tow or haul anything, it's just a daily driver for me.
Thanks again!
Jeff
I don't know about the big blocks but I've got 2 small blocks a 78 chevy 1 ton with a 350 and a 78 K5 blazer with a 400 and both have over 250K miles on them. I just change the fluids and keep every thing maintaned.  and the 1 ton has pulled everything from snowmobiles to kenworths down the highway.  (that did cost me an automatic tranny however)
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 506 Guests (See full list)
