No Start After Fuel Pump Replacement
Replaced the fuel pump on my 2000 silverado and have no power to the pump,,checked the relay and fuses,,all seem fine. looked for broken wires but found none,,could it be a glitch with the security system? makes me wonder if the orginal pump really failed? replaced with a oem pump so it should work right? need help with this one everyone..
i know this sounds dumb but did you check all your grounds ? and did you prime the pump ?
found the problem,,,hot lead from the fuel pump relay to the pump had a break from corrosion......located it right under the front left cab mount to the frame where the harness runs through,,grey wire must have had a small slice from the factory upon installation i think and just corroded after time and broke!! spliced in a new section of wire and it runs good again..thanks for the response i would have never thought thats what it was,,, but it was...NOW the wife wants to know if i need the new pump i put in??? told her if she wants to send it back get to removing it and get it out and we'll send it back.....she said forget it...ha ha..
    appletrav
    appletrav
  • Who's Online   1 Member, 1 Anonymous, 325 Guests (See full list)
