Heated Seat Not Working Correctly....
Now that it is starting to get a little cold at night I have been using my heated seats. I'm not sure if the passenger side does the same because the women isn't in the truck late when I leave work. It will work good for the first 5 or 10 minutes and then shut off on me. I click it and it will go on for maybe 5 secs and then off. Then if I do it alot it will just turn on for a 1 sec. If I leave it for a few, it will go on for a few minutes then back off. I can hear a relay of some sort clicking on and off as well when the lights shut off. Seems to me something is heating up maybe. Any help would be great. Its on my 04 Silvy. Thanks
Sounds like a bad relay. I would replace it and see if that fixes the problem.
BTW - where do you live that you are using your heated seats in Aug?
Where is the relay?
I live in Western Mass. It got down in the low 40s here. Chilly enough when you only have on a dress shirt.
There are a lot of them located throughout the vehicle (my guess would be near the fuse box; listen for clicking noise when cycling the switch). Stop by an AutoZone type store parts store and ask them for the part and they can show you a wiring diagram on the computer. If not, you may need to buy a repair manual (or just look at one in the store or see if your local library has one).
Hope this helps and good luck.
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
