2001 Yukon 4wd Noise
I have a 2001 yukon 4WD 110,000 mi. that growls when turning to the left, either a slight turn or a hard turn. I just replaced the right wheel bearing because all indications pointed that was the problem. Growl remains. Does anyone have any other suggestions and tests to perform before I replace any more parts?
Dave T
Dave T
Decided to also change the left wheel bearing and that fixed the problem.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
