Drivers Side Window Works Only Ocassionally
hey any help, 2003 2500hd driver side window works ocassionally, will work fine one for awhile then it will not work, sometimes when it does, it is very slow others it works like nothing is wrong, any ideas
Could be motor, but also check to make sure that the rubber edge where the window goes up and down in between is not folded in. This has happened to me before and it slows the window down and is not noticeable if you are not looking at it. check to make sure yours didn't get folded in by accident.
