Door Panel Removal Help
I have a broken door handle inside to fix.. I have the panel clips all done, and it seems the only hang up is around the electric door lock/ door window and door handle area.. Any ideas/info on how to free this area from the door??
Also I suddenly don't have any power locks,, does anyone know where the relay that controls this circuit is ?
Thanks
Todd
you need to pry up the window control / door lock panel.
stick a screwdriver in between the plastic and the door panel and it pops up.
to get the panel off you have to lift it straight up and it "un-clips"
but dont pull it off too fast you have to unplug the door light :)
if you cant figure it out ill take pics for you.
Sorry to invade, but I was curious as to how I would do this with my truck that has manual windows. Do I absolutely need that window crank snap ring tool to remove the window crank, or could I use something else to get the snap ring off? My right door speaker likes to act up on occasion, so I might get a replacement speaker set eventually and need to know how to get the crank off.
P.S. This page might help you out some, mtnskier, even though it's for manual windows.
on the manul window crank on both my 97 and 88 . all i did was push pannel in slighly were crank was and use a real small flat head screw driver on each slide of clip to push it off.
+1...
....just watch out those jesus clips can fly...
    Joegstfsn
    Joegstfsn
  • Who's Online   4 Members, 0 Anonymous, 653 Guests (See full list)
