Removing Grille Bowtie On Gmt-900
How do you remove the bowtie from the grille of the GMT-900 Silverados? I believe there are two round holes, a pin that sticks through, and what looks to be like "clips" holding it on. I figured the clips just need to be pinched inward but I want to be sure first. Also, can this be done without removing the grille from the truck?
Thanks.
:thumbs: daddy why don't you write a tech wiki on how to take off all of the stinking badgers? Forget that question, it doesn't apply to post count does it. :lol:
Sorry Tyler I'm being a smart ass, I don't have an answer to your question I was just getting my thread jack dig in before it goes there. You'll get the right answer soon, there are SOME people here that can't stand any badges or logos on their truck so you'll get answered shortly.
I figured those tangs were all that held it on. Do you need pliers or anything or is hand squeezing enough? What do I need to be careful of; not squeezing to hard and breaking the tangs?
I used a plastic door panel remover to lift the bowtie, and pry it. Pushed the tangs in with my thumb.
Yes, a buddy broke one the tangs just prying it off from the front
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
