Steering Shaft Question.
Will the steering shaft out of a 07 Classic fit a 04? I know where a wrecked one is and was going to grab the shaft out of it. And did they resolve the problem by 07 or leave it up to the aftermarket?
Thanks,
Damon
I think as long as both trucks are simular (1/2 ton) the "classic" bodystyle shaft should fit . Others here will know for certain . I know my 2004 sierra had a couple shafts put in and the "clunk" would come back. My dealer then installed one with a grease fitting on it. Then maybe every 10-12mos. I would give it alittle grease and be good to go again. A poor design for sure.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,242 Guests (See full list)
