04 Navigation Not Working At All
ezrenew
I was searching, searching but couldn't find right answer for me.
I have 04 Escalade Platinum which is stock-full-option and LCD is not the touch screen, it's old version of GM.
My problem is,
Head Unit is freezed, all buttons are not working at all.
only scroll-stick is working, steering button is working.
cannot change the Mode(CD,Radio,XM, etc.)...
I was thinking about getting new factory navigation with Touch-screen one.
I like after-market HU, but I want to keep factory 6 disc also.
If I have 05 touch-screen navigation, does it fit right ( antenna, plugs, jacks, etc.)?
Is there any other navigation that work with factory 6 disc player?
Thanks. :P
Lee
Try disconnecting the battery cables, then touch the two disconnected cables together. That could help. If you are just going to upgrade to the touchscreen (which I would recommend). It will work with everything you have now. If it is not unlocked, you will have to take it to the dealer to unlock it for you. Good luck!
My problem is,
Thanks. :P
Lee
Thank you, kses123!! I will try that battery disconnecting first when I get home. I hope that works!!
by the way, do you know how much do they charge to unlock?
If I get DELPHI TRN800 do I still need unlock?
Thanks always!! :P
Lee
My problem is,
Thanks. :rant:
Lee
No problem Lee! If you buy a brand new Delphi one, you won't have to have it programmed. I got mine off of ebay for pretty cheap. Most of the nav's on ebay include the antenna and disc, which you don't need since you already have those! I asked a guy if I could still buy it without those things and he cut like 300 bucks of the price! So, that was nice. Dealer will probably charge an hours time, so probable like $80? Luckily, the guy who I got mine from had it unlocked so I just plugged everything in and was good to go!
Keith
Thanks always!! :P
Lee
My problem is,
Thanks. :rant:
Lee
I did disconnected battery and re-connected, But it's not working at all.
Currently, I can use map scroll stick to move map, but all buttons are not working at all.
And I can see it shows FM 96.9Mhz on the screen with playing CDs.
I can change the 6-disc by press 1 to 6 buttons and it plays okay.
I think Navigation HU is only problem.
Anyone knows which In-Dash-Navigation work with factory 6 disc and rear entertainment, etc.?
Thanks.
Lee
Sorry to hear that. I guess it's time for an upgrade!
you need part number... 15800001
email [email protected], I got my nav from him on ebay, and he was great to work with. I told you earlier that he
cut the price for me because I didn't need the map disc or the antenna.
Thanks.
Lee
Hey, kses123, Thanks for your Fast reply!
I was looking for 15800001 as you told me here, and I also found 15800000
and they have little different option like this,
I found the following at http://forums.trailvoy.com/
15800000 WITHOUT Y91 or Y92 Option. (Bose Luxury Option)
15800001 For vehicle with Y91 or Y92 Option. (Bose Luxury Option)
UQA is the Bose speaker code for all year GMT360's and has nothing to do with either Lux or non-Lux amps. Dealer should be able to program the Bose Nav unit for either amp. Difference is: non-Lux has the analog amp which has variable inputs for volume, fader, bass, treble, etc. Lux has the digital amp which has a constant level 2ch input and the HU controls amp output and functions via the Class II data bus.
My '04 ESV is purchased on late 2004 when '05 came out.
And it's Full Option called PLATINUM EDITION that has BOSE SYSTEM/6-DISC/XM/ON STAR/REAR ENT./ETC..
I don't know which one is right for me 15800000 or 15800001
Thanks.
Lee
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,258 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
