No Drivers Side Headlights, High And Low 06 Silverado
sledog
My drivers side headlights both high and low beam are not working. Its not the bulbs, fuses are fine ( 4 individual fuses for each headlamp) but no power at fuses. Passenger side works fine, fog lights work fine as well as DRL's. Swapped relays between fog lamps and high beams and they both work. Any suggestions.
I don't know, loose wire, bad ground. My '99 had a loose wire, but it seems to be fine now.
If I was close to my dealer, I would just take it in but I'm out in the middle of nowhere and going to be here for a few weeks. I might have to shut things down early and see if there is an obvious problem other than what I stated above.
If you have a Volt Meter you can check power at the Lamp Connector which according to the post would not have power as you said it not the lamp. Then try and test at the fuse. It sound like a power or grounding issue. If under warranty take back make the dealer.
