Pedal Vibration
nobrakes00
Hi There!
I have a 2008 Silverado Ext Cab 5.3L with 8500 miles. I love my truck, but have noticed a slight pedal vibration in the accelerator pedal. It seems most pronounced between 50-60 mph, and is intermittant. Perhaps I'm just very sensitive as I had someone else drive it and they claimed they didn't notice a thing.
Any advice would be great.
Vibration in the accel pedal based on speed is usually a sign of an off balance tire (or 2, 3 or 4 tires!) if it's that slight and only at those speeds, the weight is off just slightly, and hits a bit of resonance at those speeds. No tire assembly machine in an assembly plant is perfect and the odd tire is a little off. If it really bothers you, take it to the dealership and ask them to check the balance on all of the tires for you. See if you can pinpoint the tire causing the issue (if it's one of the front tires, you might feel it in the steering wheel). If you feel like really digging deep you can rotate your spare tire with each of the wheels on the truck to see if you can find the culprit as well.
Another possibility is a little rust buildup on a brake rotor hitting the caliper, but it's more likely an off balance tire.
Overall if it's just a minor thing that doesn't really bother you, I wouldn't worry about it.
Hey Thank You! I really appreciate your insight - sounds very logical.
Hi There!
here you go bud
6-06-05-001B: Information on LMG, LC9, LY5, LH6, L76 Change in Exhaust Tone or Sound for Active Fuel Management (AFM) System Equipped Engines in Four Cylinder Mode - (Feb 26, 2008)
Subject:Information on LMG, LC9, LY5, LH6, L76 Change in Exhaust Tone or Sound For Active Fuel Management (AFM) System Equipped Engines in Four Cylinder Mode
Models:2007 Buick Rainier
2007-2008 Chevrolet Avalanche, Silverado, Suburban, Tahoe, TrailBlazer
2007-2008 GMC Envoy Denali, Sierra, Yukon, Yukon XL
2007-2008 Saab 9-7X
with Active Fuel Management System Vortec® GEN IV 5.3L or 6.0L V8 Engine (VINs 0, 3, J, M, Y -- RPOs LMG, LC9, LY5, LH6, L76)
This bulletin is being updated to include 2008 models. Please discard Corporate Bulletin Number 06-06-05-001A (Section 06 -- Engine/Propulsion System).
Some customers may comment on a change in the exhaust note or tone when an Active Fuel Management System equipped engine is in 4 cylinder mode. Some drivers may also notice a very slight vibration in either the accelerator pedal, floor pan and/or the steering wheel. This is a normal condition for Active Fuel Management System equipped vehicles and no repairs should be attempted.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2072530&from=sm#ss1-2072530">
Customer Information on Active Fuel Management
When the Active Fuel Management System is enabled, physical changes take place within the engine that allow it to run as a 4 cylinder motor with accompanying additional fuel savings. The change in exhaust tone is expected as all sound from the exhaust is the result of combustion in the engine. The ability to perceive these changes in sound are kept to very minimal levels as the Active Fuel Management System is only activated during steady state/near steady state driving or during coast down. In both of these situations, the load on the engine is minimal and general exhaust volume (sound) is low. You may give a copy of this bulletin to your customer.
  • 3 weeks later...
nobrakes00 I have the same problem as you described. Did you do or try anything to fix the problem?
Sorry, I haven't logged in for a couple of weeks...
I took it to the dealer earlier this week to redeem a free oil change, and mentioned this issue to the service advisor, but he looked at me like I had asked the freakin' square root of something!
Btw... I usually change my oil and do minor mx myself, and sure enough, the tech must have checked my air filter too, and didn't screw it back in. Uggh! I'm going back tomorrow, so I'll check.
ok...thanks nobrakes.....
I also noticed this vibration since I put Castrol Synthetic oil in. Before I noticed this vibration I was using the regular Castrol GTX.
I guess I could try and switch back it see if it goes away, but I'm tempting to bring the truck into the dealer.
I have a 08 Vmax that does the same thing. First I thought it was the driveline, then I've come to the same conclusion as the bulletin above. It's the AFM cutting 4 cylinders out that causes this. Oil would not be a cause.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,202 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
