Nfl - Divisional Playoffs - Pick'em
VMax2007
Baltimore @Tennessee
San Diego @ Pittsburgh
Philly @ NY
Arizona @Carolina
I will say this, if Baltimore wins their game they'll win the Super Bowl
Philly @ NY
Arizona @Carolina
I'm going on record to say Baltimore sucks.
Just like when my Titans were underdogs against the Steelers and nobody gave them any chance... here we go again. Hope Flucko has fun running for his life, do your thing Big Al.
Philly @ NY
Arizona @Carolina
What's with the "^Respect Deserved" Custom Title Umberto? :uhoh: Your truck deserves respect??? :bs:
You are about to lose your $100 on Sat. :P
I hate Baltimore, can't stand Ray Lewis or the team, and what pisses me off even more is when they play good. If they play Pittsburgh for the AFC title they'll win, Ben will suck ass, throw who knows how many interceptions. I'm already getting psyched up; man I can't wait.
Well being the carrot points up to the Titans logo...
But that's not the Titans logo. :bs:
It is in my world.
If I took over that team their uni's would be all shades of black.
Dan you fag, figures you'd pick the Ravens :uhoh:
Well, this is my reasoning. The Jets beat the Titans. Then the Dolphins beat the Jets. Then the Ravens beat the Dolphins. By the transitive property, the Ravens should then beat the Titans. :uhoh:
Hahaha DUH!!
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,355 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
