Tow/haul
2005 gmc sierra z71
the tow/haul doesnt work. I removed the cover on the column and traced the wire out of the lever to the plug everything appeared ok.
2005 gmc sierra z71
Thanks for checking. Let us know if anything else goes wrong! :D
2005 gmc sierra z71
I'd see if there are any codes set that would send you in the right direction. There are solenoids and control modules that could be the problem. Let's see if anyone else has helpful info
2005 gmc sierra z71
I actually had a scan tool put on it Friday, and everything was fine. I was wondering if anyone has had any trouble with the button itself?
I've heard of the wire(s) in the column (orange/white color) breaking on the inside where it bends to leave the shifter into the column. I haven't had to fix this first hand, just relating what I heard from my uncle who had to replace a section of wire in there because the metal inside the wire had broken. I think he said the insulation coating was still intact though. Don't know if this will help you. Good luck tracking that down.
I will put a meter on them and get back. Thanks for the input
    JustusTX
    JustusTX
  • Who's Online   3 Members, 1 Anonymous, 711 Guests (See full list)
