Wrecked The Truck, Messed Up Cai Box
Kinda new here. I had been doing pretty good for about two years, but teenage stupidity finally caught up with me last monday evening. I was almost home, and its often easier for me to cut thru a church parking lot for me to get the hill. So the lot is snow covered and icy. Really icy. I didnt think about the ice, and figured what the heck, I'm gonna cut some dougnuts. BAD IDEA!!! Went to make a turn and the front tires didnt agree, ABS kicked in, and off i was!!! Luckily, the chuch stoped me =[ Did about $2500 worth of damage to the silverado, including bowing the hood pretty good.
My question is, with a cold air intake, can that air filter get moist, or even wet? I beat my hood down good enough to drive until i can get it scheduled in to fix, and earn the $$$ to fix it too. Its supposed to come a pretty good snow in the next few days and I'll probably have to get out when it snows. Can i still run my CAI or should i try to put my original system back on?
Also, heres my parts list to fix it.
-hood
-fender
-grille
-headlight assy.
-headlight mounting bracket
-front bumper
-top plasic piece for the bumper
-lower bumper valence
-Radiator support
Look up Outerwears filter covers. They make covers for filters that block water. People with ATV's all over the place use them.
And tell Jesus you're sorry!
sorry to hear you messed your truck up, we've all done stupid things at one time or another. hopefully you intend to pay for any damages to the church (if there are any). i wouldn't run an open cone-type CAI in rain/snow. either make provisions to protect your filter from water or reinstall the oem air box.
Luckily it didnt do much damage to the chuch, only busted a PVC conduit pipe, and didnt hurt any of the wires inside. Its just a matter of getting an electrican in there to unhook the wires and slide the pipe over them.
As for insurance, i woudlnt have turned it in even with full coverage unless it totaled the truck. I dont really like being called "one of those people, fyi." Im mature enough to know it was my mistake and am willing to own up to it and pay out of MY pocket, not the parents like a lot of kids. That includes the church first, then fixing my truck. Luckily its the church i attend
. Y'all ever heard that song, Jesus Take the Wheel? Well he did that, and ran me right in his house :cheers:
. Y'all ever heard that song, Jesus Take the Wheel? Well he did that, and ran me right in his house :lol:
Haha I'm just messin' with ya. At least you took responsibility for it. Maybe toss an extra $20 in the plate next Sunday. Lol
VMAX2007,
Thats a fact! I wanna know a a red blooded American guy would wouldnt hit it! :D
hockeypro1411,
Yeah, i figured you were. My reply sounded meaner than i meant for it to. No harm no foul. :lol:
    Bulldogger
    Bulldogger
  • Who's Online   3 Members, 1 Anonymous, 728 Guests (See full list)
    • I figured you would know about it.
    • It added a cost layer to an already limited production supply. True that.
    • Swap costs and supply/demand balance. When a barrel comes out of the ground the entire range of products are present but not all at the same percentage.    Breakdown of Refined Products The following table summarizes the approximate output from a standard 42-gallon barrel of crude oil: Product Type Gallons per Barrel Percentage of Total Gasoline 20 gallons 45% Diesel Fuel 9 gallons 21% Other Products 13 gallons 31%   Most of that diesel figure is 'straight run' or cut from the barrel. Gasoline 'cut from the barrel runs 0 to 20% at the crude. So in the crude unit there is more diesel the gasoline, usually.  The full refining experience however gives the tabled values. Ego there is half the diesel than gasoline after the 'first crack' That could be an FCC unit, or Isomax or....   Those units take heavy products and break the big ones into little ones. Those numbers are harder to get hold of but directionally it ends up the same.    Really light products are very profitable. Ethylene and Propylene to name two. Those are cracked from slightly heavier feeds like NG and Propane and Ethane. The cracker harshness determines the feed for distillation. Those feeds come from less profitable products like diesel and gasoline.    So...there is a swap cost. How much market is there TODAY and what crude am I running TODAY..... what is my process capable of always.    There is this as well. The USA uses allot more gasoline than it does diesel so in the cracker the process is tilted to gasoline production which....limits supply of diesel. OTR uses the most and it has different requirements than automotive and agricultural.  Limiting auto products.    You are correct however. It is less refined, just less of it. Allot less.
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
