6.0l Flashing Check Engine Light
03bluess
:cheers::D:cheers::D I have a silverado ss with the 6.0L my check engine light is on and when kicking the truck down there is nothing there it feels like i am drivng a 4 cyinlider. i checked the code and the code reads massaive air flow and miss fire. i brought it to the dealer they told me it was my o2 sensor before the cat. i replaced it and it still does it. Has any one had this problem? please any information would be very helpfull. thanks. Dave
A flashing CEL means stop. Driving further can damage critical components (like catalytic converters). A solid CEL mean check when possible but isn't such an immediate cause for alarm.
Pull the codes and fix it before more damage is caused.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 1 Anonymous, 544 Guests (See full list)
