Heated Seat Issues
12345
hi all,
i have a 2001 crew cab with power, memory and of course heated seats.i,m getting intermiitent seat heat.when i first start the truck and turn on the seats they do,nt come on.then i cycle the on low off button several times and then they sometimes run.they also sometimes seem wrong in there heat setting,low goes very hot and high seems like less heat.cycling the switch does,nt always get them working.they never come on with the first try apone starting the truck.i took the door panel off and replaced the door control switch...didn,t change a thing.i was sure it was the switch but i was wrong.
anyone have any suggestions?from what i gather these seats don,t have a bcm so i don,t know what to check next.are these seats controled by the main computer?
p.s i,ve tried the cycling of the switch just sitting in the drive way(to remove the vehicle motion)just incase,it always behaves the same.
thanks cj
Hi there and welcome to GM Trucks! :D
The first thing I would look at would be the switch itself. It sounds like it is a switch issue.
the switch has been replaced,no change behaves the same.
the hi, low , medium relay may be flaky. find it under the hood and replace it. they usually arent much $$$$ if not it is probably the button, but hopefully not the wiring!!
what relay would that be?there is no medium setting on these seats.it,s a 2001 it has no bcm o r any computer stuff.
i,ll see if there is some sort of seat heater relay though.
also(for the third time)the door button has already been replaced,it did not help.
thanks cj
the hi, low , medium relay may be flaky. find it under the hood and replace it. they usually arent much $$ if not it is probably the button, but hopefully not the wiring!!
thanks cj
it should be in the black box by the master cylinder. the lid should contain a description of all the different relays and fuses
  • 4 weeks later...
i believe there is a module for the seats and that may have a problem.
i wonder if it could be the fuse block in the engine compartment?seems to be the cause of many electric problems.
cj
  • 5 weeks later...
cj
m o v e i t u p
If all else fails...
I would get a factory wiring diagram and learn how the system works, see where all the components are located, which color wires, etc.
Then I would connect a multi-meter to various points starting on the switch and leave it there as I use the vehicle. If the switch is always supplying power as it should, then move it down the line to the next component. Etc.
This way you could "see" what is going on with the various components when this happens.
If it was something under the hood, I would just run wires say out an opening of the hood and through a partially open passenger’s side window to a mulitmeter in the vehicle.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 1,203 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
