Extended Cab Door Shutting Question
04hd
i got the extended cab model and was wondering if there was a way to tighten up the door. when i shut my front door it does not sound solid. im thinking the rear door is not tight.
Mine too, 05, the back drivers side does not shut solid always so then the frt is loose also. My 00 did the same thing on the ps side.
It is possible, but I do not know how. I had the same problem with an 07, and I had the dealer's body shop adjust the top latch on the roof that the open edge of the passenger door catches on to. Can you loosen the bolts/fastenings and reposition that latch?
On mine if you don't shut the back doors hard they will not fully close making the front doors seem loose. After I shut the back doors with some extra strength I grab hold of the leading edge and do a push-pull check to see if they're fully closed. If they move I try a little more force.
    BigJake
    BigJake
  • Who's Online   2 Members, 0 Anonymous, 631 Guests (See full list)
