Scan Tool
Ok I dont post on here much but I am looking for a scan tool or?? to read the tire pressure on a non DIC truck. My wifes Trailblazer has the system but we can not see the pressure. Only a idiot light. Is there a scanner that I could read it??
Thanks
Mike
Tire pressure gauge, free at most tire centers...The TPMS is usually off 4-5 psi.
You are right about the tire gauge but it would be nice to know what tire set off the sensor with out having to play a guessing game. And there are other things a scanner can tell you..
I don't know which scanner would read it, but EFI Live has a software and connector package for a laptop that is supposed to do about everything including resets, for $300. There are many scan tools out there for much less, but most are very limited in what they do. I'm buying a EFI Live. But, if you just want to find out where the TPMS light comes on, start the car and let air out of a tire until the light comes on, then measure the pressure with a gauge.
[/quote
I bought a scanner from Advance auto Actron CP9180. It did not read the TPMS. Just looking for a tool has a few more bells to look at.
Just check each tire with the tire pressure gauge and see which one is off. The TPMS light usually goes off when a tire gets to +/- 10 psi of what it is supposed to be set at. By rule-of-thumb most tires on light trucks and SUV's are set to around 35 psi. You can also check the side of your driver's side door to see what the exact pressure recommended by the manufacturer is.
I am past manualing checking the pressure. I am just looking for a new gadget to read other data but would also like to read tire pressure. All I am asking is there a scan tool beside the tech ii that will read more info. I am not trying to sound rude. But most comments are basicly just check it your self with a tire gauge.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 692 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
