Carriage Works Billet Grills?
I have a 2008 GMT900 Z71 I was looking to put the carriage works black chrome billet grill. I can't decide between the bolt over and the one that requires cutting of the original grill insert. Does anyone know if you can tell the difference in the bolt over.
A member on here (Daddy) I believe has one a a detailed thread with pictures. His is a replacement style. I will try to find the link.
True, but daddy has a Sierra.
Thats true...good call Jeff....
Here is the link anyway http://www.gm-trucks.com/forums/index.php?...=carriage+works
The process would prolly be a little different on the Silverado.
I think it looks nicer to have a replacement style not a bolt over.
Replacement bolt-overs just don't look right. If you're going billet, go replacement so it sits recessed from the grill surround, as it should. :D
As for trying to overcome the ugliness of the Silverado, you'll need more than a grill. :dunno:
:chill: My old CW Billet grille looked just as shitty as yours does. :lol:
As for trying to overcome the ugliness of the Silverado, you'll need more than a grill. :lol:
+1 :dunno:
Thanks for the inputs i will probably be going with the bolt over. The billet pieces are close enough together that i should not be able to see behind it. Oh an sorry to say daddy but the recessed look of the grill is more of an opinion as is your opininon on your GMC.(Misguided as it may be) :D
I had a 2004 Silverado with a bolt-over billet grill. It looked ok from a distance but when you get up close it's not as flush with the outer grill shell as it should be. It made me wish I went with a replacement style even though there is more work involved.
It is my opinion, but it's right. :dunno:
Thanks for the inputs i will probably be going with the bolt over. The billet pieces are close enough together that i should not be able to see behind it. Oh an sorry to say daddy but the recessed look of the grill is more of an opinion as is your opininon on your GMC.(Misguided as it may be) :confused:
It is my opinion, but it's right. :rollin:
Can't speak for the Silvys, but my Bolt-Over CW Billet grill I used to have hid the OEM grill just fine, you could only see it if you put your face right up to it within a few inches. It was also about 1/4" recessed from the surround...so daddy, you are not "right". :lol:
Thanks for the inputs i will probably be going with the bolt over. The billet pieces are close enough together that i should not be able to see behind it. Oh an sorry to say daddy but the recessed look of the grill is more of an opinion as is your opininon on your GMC.(Misguided as it may be) :rollin:
It is my opinion, but it's right. :lol:
How could I be when you always have to be? :confused:
:lol:
    bellssn690
    bellssn690
  • Who's Online   2 Members, 0 Anonymous, 522 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
