Had a chirping noise ,change idler pulleys, no change ,It was the fan clutch , it had slight movement lft to rt and up and down, got one from Advance Auto ( MADE IN USA)
corrected problem !! THAT IS ALL! :lol:
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,130 Guests (See full list)
