Rough Country Lift
Has any body seen this lift from rough country, its an non torsion bar drop. I seen that there on sale for 1200 and was wondering if it was worth that or was it a piece of crap lift, they also have the regular for 1000. Or is it just better to save my money and go with a body lift? I really dont go off the road i just want to get 35's on my truck, or maybe just 33's with a body, i know you could probably go an 35 with an body also. I got an 06 reg. cab so i have electric fans but i have an 5spd and want to know how tricky it would be with that in the pic. Also would a body lift mess with the front hooks and the rear towing? I have seen pics were they are spacers from the hitch and the frame, and that looks like crap. For now i have 285 with the keys cranked and i just want alittle more higher than what it is now. Thanks for any help
got one on my truck and love it!!!! i have the 1000$ one, make sure you get the steering stab...ive had mine on for at least 15,000 miles and i tow, offraod and do everything, nothing is worn out, it aligns perfectly and its just a good kit...
So do you have the 3" body lift on the pic or just the 6" lift? A buddy of mine has the 3" body on a 00 gm its the z71 reg. And he told me to go with the suspension and he said that the rough country sat higher than a fabtech? I wouldnt figure there was much difference in two lifts to be like that but he said his body lift was close to the fabtech hight and he said that the guy had an 6" on it. Do you think it would be worth going with the non torsion drop?
i would just go with the 1000$ lift, i also have a body lift on my truck only because i like a little more clearance when i offroad, all lift kit vary a little on height due to torsoin bar setting, but all lifts are within specs for alignment
I have the non torsion bar drop kit on my 06 silverado (the $1200 one) i have no complaints about it so far. I wouldnt go with the cheaper one.. for 200 more dollars you get a ride that is MUCH smoother.
I just put the 7.5 rough country lift on my GMC 1500 this weekend. Looks great but I am having braking troubles. When I go to stop, my truck vibrates. The wheels are balanced and the alignment was done. Anybody else having this trouble, or do you now andy fixes for this
Did you remove the retainer clips on the rear axle when the new wheels were put on? If not, thats what is causing the vibration.
Not sure if he did or not. I will check that out. Any other ideas or do you think that will cure it. It only happens when I brake. Not while I am driving.
hey there, just wondering where you saw this kit for a $1000. sounds like a steal to me, i wouldn't mind checking it out. thanks...
  • 1 month later...
Its $1000 on Rough Country's web site AND ebay depending on what you prefer. I'm close to buying one myself, but not sure whether to go with the $1000 or $1200 kit.
    Sothpaw27
    Sothpaw27
  • Who's Online   3 Members, 0 Anonymous, 578 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
