Bulb Question
I contacted VME.inc who sells hid kits. They said that their 9005 kit is the same as the 5202 kit. The 5202 kit is the same as the fog light. Has anyone here had any expierence with hid fogs for a direct fit. No grinding, splicing anything like that.
Have a bulb that went out now and looking to replace. Have 8000k in the low's looking to possibly match. since i have to get new bulbs. Looked at the putco's but for 32 might as well pay the extra 25 and get the hid???
Opinions????
Thanks in advance.
I'd be very interested to know this as well.
I want HID's in my fogs so bad now after I put them in my lowbeams,but I don't want to grind,splice,or silicone anything either.
i have seen a kit for like almost 200 but not spending that much when there is kits all over ebay for 50 to 60.
Someone on there has to have those kits. I seen one other for 99 by wholesalehid.com
Hopefully someone on here has some experience with them.
Yeah,And I can't even get a trade number for the bulb,The only number they give me in the parts catalog is the actual GM part number which is 15839897.
I looked at the bulb itself,It has "PS24WFF" along with "8C20TB" below that imprinted on the metal base of the bulb itself,And its made by Phillips because thats molded into the plastic base part of the bulb.
I am getting so frustrated with trying to find these bulbs. Seriously why aren't they out there.
Anyone........ Anyone........
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,130 Guests (See full list)
