Hey I was wondering what kind of shift kit I should get for a 350TBI with a 700R4 automatic transmission? The motor is pretty much stock also. Just want to hear some opinion on whats the best way to go to get a better shift outta her. Thanks
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,065 Guests (See full list)
