Get ready...Here comes the the Long Tubes vs Shorties debate! :lol:
I myself have had good luck using shorties in the past. I actually have a set of JBA Headers waiting to be installed for my truck...so until they are in, I can't really give you too much help...if you find anything let me know...if by any chance I get them installed soon, i'll let you know how it turns out.
The one's I owned in the past did not give me any problems whatsoever...they held up longer than the truck did...but then again it was a dodge. :lol:
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,065 Guests (See full list)
