Guage Lights
I am thinking of putting White LED bulbs behind the Guage in my 01 Sierra.
What bulb goes behind the guage?
Does anyone have photos of this
Only blue, but white is def available.
Requirements.
- Flat Head Screw Driver.
- 7MM Socket.
- 6 Bulbs.
- 6 Light Bulb Housings.
What To Order.
- Order 6 WLED-x4 LED Bulbs.
http://www.superbrightleds.com/cgi-b...1.29175&next=0
- Order 6 Light Bulb Housings.
http://bayareaamusements.com/Merchan...oduct_Count=23
1) Tilt your steering wheel all the way down.
2) Turn on your truck and put your gear all the way down to first gear. Then turn truck off.
3) Use your fingers and wedge out the dash trim, it should just come out.
4) Use a socket and remove all 4 bolts holding on the gauge cluster.
5) Unplug the wire attachment that you will see on the backside of the cluster.
6) Remove the black covering of the gauge cluster that's on the backside, use a flat head screw driver.
7) You will see 6 light bulb, remove them and replace them with the new ones.
8) Reinstall the whole cluster as you removed it, then your done.
Thanks-That is exacxtally what I was looking for!
I just placed the orders and will attempt the install when they come in.
Are the bulb housings tricky to get inplace, or does it fitn in the stock bulb housing.
Requirements.
- 7MM Socket.
- 6 Bulbs.
What To Order.
Did you also do this with your HVAC control? BTW that looks really good.
Requirements.
- 7MM Socket.
- 6 Bulbs.
What To Order.
03 and up are a pita, 99-02 are a breeze. Keep in mind this is for a yukon, but I'm pretty sure its all the same for sierra
Requirements.
- 7MM Socket.
- 6 Bulbs.
What To Order.
Did you do it to your HVAC control?
I am going to have someone else do the HVAC and some other lights. My 01 has the same dash as the one in the pic so I think it should be the same.
Thanks again for the help
I got my LED's today and a few minutes later they were installed... I love the look.
The Speedo, RPM, and Fuel gage light up real nice but the other 3 (Battery, Temp, oil pressure) are really dim...
Any ideas? I will try to post a pic later...
Thanks Frost for you easy instructions!!!
Wow that looks good. So you say it is harder to do with NBS?
Mine is an 01 it was waaaay tooo easy
I had some of the bulbs in there backwards...
here is the final product.
I don't think I could pull the look off with my truck but I really like it.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   3 Members, 0 Anonymous, 1,101 Guests (See full list)
