Rear Seat Video Input
hey guys
i installed a factory nav unit in my 09 sierra
used a 09 unit and vss and voice wire
no features lost, still have my bluetooth and everything else.
i noticed that it has an aux input for audio, and an aux input for video.
does anyone know the wire harness i need to use the aux video input?
also is the video jack on the vss wire harness and input or output for the dvd?
i am getting the GMX-322 lockpick
so i can alway use those inputs to watch my ipod videos
but i think it has the line at the top of the screen, like when you are using the backup cam.
i was just would like to know if i could get the wire harness for those rear video inputs
so i could just hit the video jack input button on my nav screen
thanks guys
plus anybody ever add the factory overhead monitor to there truck?
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
