Going to buy the XM Upgrade kit from the dealer. I am affraid that the dealer won't install it because they would have to drill holes in the roof. Does anyone know where to place the antenna on the roof? Any help would be greatly appreciated. PLEASE HELP!
The kit should come with a template on where to drill them.
What kind of silicone should I use when putting the antenna on after the holes have been drilled?
You shouldn't have to use any,There should be a gasket on the antenna.
Make sure you touch up around the holes though with touch-up paint to prevent rust around them.
Thanks for you help
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,129 Guests (See full list)
