04 Sierra Ac Trouble
faulty HVAC door actuator on the passenger side. It's either bad or has over traveled and hung open. It's about $200 from the dealer or 30 minutes labor for them to reflash the BCM to update the actuator travel limits.
Is the A/C compressor in the engine compartment kicking in?
I assume you have an electronic control? Try moving it to hot, then back to cold a few times. See if you can hear a door moving. (There is a little door which moves back and forth for cold/warm/hot.) This door would be somewhere under the dash.
Does it get hot when moved to hot? Then cool/warm when moved back to cold?
If compressor is kicking in and the door seems to be working, might want to put gauges on the A/C and see what the pressures are.
This has happened to me twice. Each time I unplugged the battery for a while and then it worked as normal again.
    ballencd
    ballencd
  • Who's Online   1 Member, 0 Anonymous, 425 Guests (See full list)
