Yukon Rear Hatch Glass Defrost Grid Connector
Brewboy
As you are no doubt aware on the Yukon rear glass hatch the defrost elements are embossed on the glass. The defrost elements have a male connector soldered into each side of the grid on the glass.
The male connector is what the curly power wire connects to from the pillars in the rear. Upon opening the glass hatch the solder joint broke and the connector came off and is dangling in the curly cord.
My question is regarding re-attachment of this connector.
Can I just crazy glue it back on or does it need to be re-soldered by the dealer?
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 715 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
