Problem With My Truck
When I try to start my truck it will fire but won't start. If I bang on the gas tank and let my truck sit for 15 mins it will start. I replaced the fuel pump(gm pump) and fuel filter. Also my check engine light came on for the knock sensor. Any ideas what's wrong with it? Thanks.
How long ago did you replace the fuel pump? What brand did you replace it with? Have you checked the fuel pressure?
banging on the fuel tank to make it work, eh! .... this suggests that the electrical contacts at the top of the pump and top of the tank are worn or corroded... did you replace the electrical connection when you replaced the pump... the banging on the tank causes a slight vibration or rotation of the pump ... then the contacts work and away you go... as long as the pump keeps spinning ... but if it stops spinning on a dead spot then ... well, you know!
    appletrav
    appletrav
  • Who's Online   1 Member, 1 Anonymous, 467 Guests (See full list)
