2003 5.3 To 6.0l Motor Swap
I am looking at doing the following:
I currently own a 2003 Tahoe 5.3 Flex fuel 4x4 Tahoe LS
I am thinking of dropping a 6.0L motor from a 2003 GMC Yukon XL 1500
I will have the complete wire harness and computer from the Yukon as well.
Correct me if I am wrong in thinking this would be a direct bolt in?
MIke
why would I need the tune if I have the PCM for it? (not that the custom tune bothers me.. just wondering.
Any way to measure for oil pan clearance? (where would it be tight?)
I am thinking of doing this b/c mine has a head gasket leak, and 110k miles, and I can get ahold of the motor for a fair price...
The 5.3L is a LD engine and the 6.0L is HD. The LD has a 4L60E transmission and the HD has a 4L80E. Oil pan is the same.
Even between a 2wd and 4x4?
But otherwise the motor will bolt up?
What your saying is the shift points and the like will need to be changed?
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 817 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
