Can You Put A 2003+ 5.3l Engine In A 2000?
Hey guys, I've just picked up a 2000 Silverado 4WD Z71 (with 5.3L V8) with almost 160,000 miles for a song. Mechanically it needs a little TLC, some of which I'm going to be doing this winter. Mainly suspension work based on what I can tell so far. I'm also trying to track the source of oil on the rear output shaft of the transfer case (oil seal, I presume?). But that's not why I'm posting at the moment...
This thing sounds like a diesel on cold start, which I know thanks to this forum is the dreaded piston slap. But there appears to be a more subtle knocking sound (not detonation knock) during steady throttle once warm. I just noticed it today, but I might be hearing things. The truck also needs new tires (thanks to the worn suspension), and it's hard to hear much over their humming on the road at speed. But it got me thinking about my engine replacement options.
I see used LM7 5.3L engines on ebay that have been pulled from wrecks -- and I know I could search local salvage yards as well -- but most of the lower-mileage examples are for 2003 and up. My 2000 has a mechanical throttle cable, while the 2003 and up have throttle-by-wire. That's the only obvious difference I'm aware of, but I'm sure I'm missing something.
So is it possible to drop a 2003+ 5.3L in my 2000 engine bay and be pretty much plug-and-play? Besides the throttle cable hookup, what else is different in the 2003+ engines that I would need to worry about?
Thanks,
Mike
Yorktown, Virginia
Thanks,
Mike
Yorktown, Virginia
The engine knock seems fairly common. I started hearing it on my 99 Z71 when starting it up and taking off right away. If I let it run for a minute or two it goes away. If I do drive it right away, the knocking goes away after about a block. It's only on the first start of the day. There was a guy from work who's immaculate 2000 Z71 Silverado did the same thing. There is a lady at work who has a year old Ford Expedition and it does that when first starting up too for the first 5-10 seconds. I've read truck ads before where they would mention: "has typical cold startup knock". Personally, I think it shouldn't happen at all. Wish this thing had a good ole' 5.7 TBI.
As for the engines, I don't think there would be much difference between the electronic throttle and cable driven. Long as you swap your intake system over it should work, unless any gearheads can give more experienced opinions?
The engine will swap over without any difficulty. The significant differences are the throttle body (you'll have to re-use your original or get a replacement) and the EGR (exhaust gas recirculation) gear (if so equipped). The '03 and later do not have EGR. You'll probably have to pull parts from your original engine anyway since most salvage engines don't come with all accessories still attached. Engine covers are strictly cosmetic, so don't worry about the difference in the shapes there.
    250.3k
    chfkief
    chfkief
  • Who's Online   3 Members, 0 Anonymous, 1,488 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
