Steering Issues Continued - Now With Video Goodness!
Ape0r
I posted this thread the other day in regard to an intermittent noise/sensation in the steering column of my truck:
http://www.gm-trucks.com/forums/index.php?showtopic=104888
I had a friend help me go over it today, there is absolutely zero evidence of any wear whatsoever on any of the steering linkages (inner/outer tie rods, pitman/idler arms) or the ball joints.
However, the steering box has a whole lot of slop in it, and makes a rather noticeable clicking noise when the shaft is rotated. Please see this video:
With your sound on, you can hear the (gears?) clicking. I wanted to do a sanity check and make sure that that much slop isn't normal before I blow $450 on a steering box. There is no pitman arm movement whatsoever when rotating the shaft like that. Note that I wasn't using the steering wheel to do that, but rather was grabbing it by the joint between the intermediate and lower steering shafts and rotating with one hand, so not a lot of torque.
A blown steering box would also explain the grinding that I have been noticing over the past few months. I am going to replace the pump while I have it apart due to a leaking shaft seal.
Thoughts? Nods on my steering box diagnosis?
Thanks!
I thought you said the tie rod ends were done?
is the truck wondering ?is it the noise? thats bugging you ? I will look at the video at home but I got to say these trucks don't puke steering gears .
did a garage listen to it?,how many miles on it?
I thought they were after shaking each wheel yesterday with the control arms supported by my jack, but I didn't have a second person to shake the wheel for me while I looked underneath until today - no movement at all in the tie rod ends or pitman/idler arms after inspecting today. Found what you'll see in the video - what seems like a hell of a lot of play in the steering gear.
The issue is an intermittent awful GRROAAAAAAAAAN accompanied by a sensation in the steering wheel that occurs occasionally when turning the wheel at low speeds. Not sure if it wandering a little or not, may have noticed something, but it may be in my head.
Hasn't been to the garage - 101k on the clock, probably 80-90% highway. No real offroading or abuse to speak of either.
I think you be alittle overzealous and are freaking out abit.
take a breath and replace the pump ,bleed it properly( tires off the ground engine off ,lock to lock several times ) and go from there younge jedi !!
I'll look at the video in a half hr
I saw the video ,omg man,change the pump and drive the truck
Haha thanks for the guidance, really do appreciate it. My experience is limited to working at a dealer as a mechanic's assistant over the summer after my first year of college about four years ago, so I'm better at changing parts than diagnosing problems :lol:. I'll swap out the pump next week.
just bleed it like I said ,you'll need a pulley puller and installer ,make a note where it is on the shaft before removal,
and I'm spent lmao
My 2001 has done the same thing for years. It also has a squeak somewhere in it. If it's not one thing it's another. And a I have another, a rattle somewhere in the exhaust at 1000rpm that only happens when it's cold. Dealer can't figure it out either. Grrrrrrrrr.
    250.3k
    Disabled Mike
    Disabled Mike
  • Who's Online   2 Members, 0 Anonymous, 752 Guests (See full list)
