Frozen001 Posted September 26, 2005 Posted September 26, 2005 I have a GMC Sierra 2500HD 6.0l gas, and I have randomly experienced a slight slip when starting from a stop. It seems like the transmission forgets that it is suppose to enguage for about 1 second, then it goes fine. This occurs randomly and not often enough that I think it is a serious problem(maybe 1-2 thime a month). I have heard from others that there is a TSB out for this problem. The fix is a simple reprogram of the PCM to fix it. Does anybody have the number I can take it to my dealer so I do not have to deal with fighting them to find the fix. Thanks!!
GM-Tech Posted September 26, 2005 Posted September 26, 2005 This may be the one you're looking for... 4L60-E/4L65-E Automatic Transmission Second Gear Start, Lack/Loss of Power When Accelerating from a Stop (Reprogram Powertrain Control Module (PCM)) #05-07-30-013 - (May 9, 2005) 2004-2005 Cadillac Escalade 2004-2005 Chevrolet Avalanche, Express, Silverado, Suburban, Tahoe 2004-2005 GMC Savana, Sierra, Yukon 2004-2005 HUMMER H2 with 4L60-E (RPO M30) or 4L65-E (RPO M32) Automatic Transmission Condition Some customers may comment on a slip on launch, low power on a launch or a second gear start when accelerating from a stop. This condition is usually very intermittent, occurring only once in a few thousand miles of driving. A Tech 2 or VDR snapshot of the event may show 2nd gear being commanded for approximately two seconds, then 1st gear commanded as would be expected. Cause This condition may be caused by an intermittent VSS signal, which causes the PCM to command second gear. Important: There are other conditions that can cause the transmission to start in a gear higher than first. The following are a few of these conditions. • Some DTCs can cause the transmission to start in a higher gear. Check for the presence of DTCs and repair as appropriate before proceeding. • Debris on top of the spacer plate or in the valve body or a leaking shift solenoid can cause a 4L60-E or 4L65-E transmission to start in a gear higher than first. A start in a higher gear caused by any of these conditions typically occurs with much greater frequency. Refer to Service Bulletin 01-07-30-036D or newer for diagnostic information of these conditions. • Placing the shift lever in the D2 position will cause a 4L60-E or 4L65-E transmission to start in second gear. Correction Important: • This bulletin ONLY applies to 2004-2005 models year vehicles listed above. • Some DTCs can cause the transmission to start in a higher gear. Check for the presence of DTCs and repair as appropriate before proceeding. Using a scan tool, check for the presence of DTCs. If DTCs are present, refer to the appropriate SI Document before proceeding with this calibration. Important: These calibrations also contain the 2-3 shift clunk calibration as detailed in bulletin 05-07-30-012. Technicians are to reprogram the PCM with an updated software calibration. This new service calibration was released with TIS satellite data update version 5 or later available May 1, 2005. Refer to Service Programming System (SPS) in Vehicle Control Systems in the appropriate SI Document. Warranty Information For vehicles repaired under warranty, use: Labor Operation Description Labor Time J6355 Module, Powertrain Control - Transmission Reprogramming Use Current Published Labor Time GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information. WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION © Copyright General Motors Corporation. All Rights Reserved.
drumset5994 Posted September 26, 2005 Posted September 26, 2005 Just a wild question...anyone know why they chose that when you put the shifter into "2" ...it stays in 2 no matter what? On my old 96 S10 (same 4l60E)...when i'd put it in 2, it would start in first, then shift to second, then hold there, etc... almost like a limiter. For my advantage, the start in second is good for non-neck breaking starts like in snow...because my 4.3L with the 3:08's in unbelievably fast in 1st...no s**tting.
gave20 Posted September 26, 2005 Posted September 26, 2005 The bulletin lists 4L60's but I assume it applies to 4L80's as well?
GM-Tech Posted September 27, 2005 Posted September 27, 2005 The bulletin lists 4L60's but I assume it applies to 4L80's as well? The information is specific to whatever models, years, equipment it lists. So no, this TSB does not apply to 4L80E.
mmmikkke Posted September 28, 2005 Posted September 28, 2005 I had a 2002 Z71 4L60E that did what the bulletin describes. Would occasionally start out in 2nd, maybe one takeoff out of 100. Now I have a 2005 2500HD with the 4L80E. I have never noticed it do the same thing (start in 2nd) but I have had a suspicion once or twice that it slipped while taking off. Problem was, it could have been tire slip while crossing the white stripes that define the crosswalk at the intersection. It's about that quick of a slip. I was bummed when I bought my 2002 and found out the 2 means 2, instead of the old way when 2 meant 1, then 2. I'd rather have 1 then 2. I even liked the stiff 1-2 shift. Alas, it's been dumbed down, like so much other stuff.
Frozen001 Posted September 30, 2005 Author Posted September 30, 2005 GM-Tech... That is close, but the 2500HD has the 4L80E I believe.... Same problem, but wrong transmission....
COSilver Posted October 5, 2005 Posted October 5, 2005 I too have experienced this maybe 3 or 4 times in the 25K miles I have on my truck. Tire spin on the white line at take off is exactly what it feels like, and yes, it is very quick. This is on the 4L80E tranny.
bpowell97 Posted March 13, 2006 Posted March 13, 2006 So what do I do to get the TSB addessed? is this something that would be covered under warranty on a 2005 with 15k miles? This may be the one you're looking for... 4L60-E/4L65-E Automatic Transmission Second Gear Start, Lack/Loss of Power When Accelerating from a Stop (Reprogram Powertrain Control Module (PCM)) #05-07-30-013 - (May 9, 2005)
KTSTEEL Posted March 14, 2006 Posted March 14, 2006 I have also experienced this, a handfull of times, with my 04 2500HD.
mello98zss Posted March 18, 2006 Posted March 18, 2006 My 2002 2500HD does it also, just like the TSB describes but it is a 4L80E. It has done it since brand new in bone stock form. I never bothered mentioning it to the dealer because it happens so infrequently; there is no way it would occur if they test drove it.
Metz Motorsports Posted March 18, 2006 Posted March 18, 2006 I have an '02 1500HD (which trans do I have?) and it feels exactly as someone described, like spinning the tires on the white stripe. Scares the crap outta me every time, thinking its going to leave stranded one day.....is it a very serious issue?
