2003 2500hd Overheating While Towing
skippy7024
15 hours ago, txab said:
Has the fan clutch ever been replaced in the past? Check it hot also. Many youtube videos showing how. You might look into the radiator having a passage blocked at some point
I have never replaced the fan clutch or water pump. I currently am disassembling to replace both.
On a side note, I did another run after I powerwashed the radiator and other coolers. I did the same run as I did before, high AC, no trailer button engaged, still pulling the same trailer. I noticed that I initially started at the tick below 210, held there for a bit, then hit 210, and ended at the tick past 217 where it seemed to hold. This is while I was pushing it hard to make it work! It is a huge difference since the run the day before (pre-power washing)! But I am still going to replace the fan clutch and water pump.
  • Replies 32
Looking for some advanced removal ideas. I am trying to get the harmonic balancer bolt out. I have the flywheel lock in place. Front the breaker bar contraption you see in the image it is still not breaking it loose. I have snapped 3 wrenches, one being a snapon breaker bar type. Any other thoughts on how to break it loose?
Thanks
    bellssn690
    bellssn690
  • Who's Online   2 Members, 0 Anonymous, 522 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
