Can't Shift Into Gear
I have a 2001 gmc sierra, today i was installing a new gauge cluster and i had to pull the shift lever down to get the old one out and the new one in. After installing it i went to shift back into park and i noticed it didn't feel right. Then i couldn't start my truck but had everything except crank. I manually pushed the shift rod at the transmission as far forward as i could and now it starts but the shift lever still moves up and down with no resistance and i don't have to press the brake to shift out of park. Also none of my gear indication lights appear except park when i have it all the way up, and i have no reverse lights either.
If I'm not mistaken, the gear shift lever is attached to the transmission by two cables. You should check them and make sure you didn't accidentally disconnect one. If I remember correctly, the connections are just above the steering column but below the gauge cluster.
Hope this helps,
Adam
<br />If I'm not mistaken, the gear shift lever is attached to the transmission by two cables. You should check them and make sure you didn't accidentally disconnect one. If I remember correctly, the connections are just above the steering column but below the gauge cluster.<br /><br />Hope this helps,<br />Adam<br />
<br /><br /><br />
The cable that runs down through the floor and to the tranny seems like it broke right before the trany. When the shift lever moves up and down i can feel the cable moving inside but right before the trany when the cable turns into a metal rod it won't move that metal rod. and also i noticed i dont have to hit the brake to move the lever any more.
<br /><br /><br />
Looks like you'll have to get new shift cables. Not sure but I would bet that's a dealer only part.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   1 Member, 0 Anonymous, 1,168 Guests (See full list)
