Transmission Problems With My Chevy Express 3500
I've got a Chevy Express 3500 with 6.o Vortec, my truck has 120 000 km. At 105 km the original transmission broke down. I bought a used one, my friend installed it, it as been on my truck for 2 days, broken again after. I've send the truck back to the used part shop, he changes it again.I've ran for 2 weeks with, and broke it again. This time I've go to a tranny shop for a rebuilt, I've made 15 000 km woth and yesterday the truck had no more reverse. I bring it again there and now it rebuit again again.
I have put 22 inches wheels on the truckabout 15 000 km since the original tranny broke down. I do delivery with this truck, I keep it very clean ans when a load it it's equal on the floor, about 3000 pounds. I deliver newspapers. I would like to know if there's something I can to to not broke again the tranny, because some people told me that it was caused by the wheels??? Could it be that or there's another cause?
I'm not rough with the truck I drive it safely.
What could i do to fix the problem without removing the wheels?
If you have awnsers told me please!!!
thanks
JOE
thanks
JOE
It sounds like you have inexperienced repair shops doing the repairs. What actually went wrong each time you went to have it repaired? As for wheel size, it's irrelevant. It's total tire height that matters. I have 18" wheels but, with a tire it is 31" total. If your van seems sluggish, and you drive mostly in town, then you'll want to consider different gears for your rear end.
thanks
JOE
IThe height of the wheels are 32, because it's low profile. I ride mostly on highwaybut in town, it's sluggiah but what do you mean by considering different gears for my rear end??
Thanks
thanks
JOE
Thanks
The rear end will be a certain ratio identified inside the glove box on a label, called RPO codes. It starts with a G for the rear end on civilian trucks. It should be something like GT4 (3.73 ratio), GU6 (3.42 ratio), GT5 (4.10 ratio) and also it may have an ID code of G80 (Limited Slip positraction feature for your diff).
thanks
JOE
Thanks
I should change for one gear up or what?
    ballencd
    ballencd
  • Who's Online   4 Members, 1 Anonymous, 595 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
