Chassis Pop Noise
Lyndongolden
My 2008 Sierra (regular cab) has a "pop" under the rear of the cab when accelerating from a stop and turning at the same time.
This is one brief pop noise...it sounds like someone is lightly tapping the bottom of the cab / frame with a hammer. It comes and goes.
The dealer adjusted and shimmed the cab mounts several times but the noise always returns in about a week. I lubed all the rear leaf springs, bed mount points, cross-member contact points, and cab mounts. Last week, the dealer replaced the leaf springs and yet the "cab" noise is still there.
HELP!
    Fishboat
    Fishboat
  • Who's Online   1 Member, 0 Anonymous, 525 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
