05 Chevy 1500 Trailer Light Problem.
GeorgiaBII
Please help I am leaving tomorrow morning for cross country trip and am desperate.
Vehicle is an 05 chevy 1500 series pickup with factory 7pin trailer connection.
I only have an output for the left brake/turn signal light at this connector. Trailer brakes are working correctly
My question is.
1. Is there a control module that would be suspect? If so where is it?
2. As a last resort can I do a temporary work around using a splice off the harnesses going to the trucks tail lights?
3. Is there a common problem I should check first?
THANK YOU for any help you can give.
James.
Keep some fuses on hand in the glove box or some where. I found they will blow when you disconnect the plug with the lights on. I try to remember to turn the off but sometimes I forget. Forgetting is one thing that has gotten easier with age.
    Gilkey96
    Gilkey96
  • Who's Online   3 Members, 0 Anonymous, 686 Guests (See full list)
