Applying Por-15 On K1500
I plan on applying some POR-15 on the chassis of my '98 K. Does anyone have a good estimation of how much I would need? They come in Pint, Quart and Gallon size jugs. I don't think a quart is going to be enough. I was thinking a gallon. Damn sure is expensive too.
I painted a Jeep Wrangler frame with por15, took about a quart. I'd say you could get away with 2 qts but I'd probably buy 3 just to be safe. It's a very thin "paint" and is easy to work with. Drys hard a rock! It's good stuff, just make sure you follow the instructions.
Thanks 07HDCC. Did you buy yours directly from the website?
Yes, directly from them. I also used their "chassie coat" paint to cover areas of the frame that still had the original frame paint. My understanding was that the por15 needs rust to properly cure/stick so using it over a painted surface wasn't recommended. In the end I used por15 for rusted areas, which was probably 90% of the frame, and then flooded the whole frame with the chassie coat. Worked out great for me and the Jeep saw two winters in upstate NY with no failure of the paint.
That is what I was looking for. I will be doing my frame next spring. Should I knock and loose rust off first?? Or a good power wash?? And did you use a roller, or brush?
http://www.por15.com/POR-15/productinfo/1GB/
My jeep frame was in pretty rough shape. I started with a good wash then I used a wire brush and a paint scraper to get the scaling rust off. I also used the por15 "metal ready" to clean it all up and help with adhesion. I used the cheap disposable foam brushes, worked fine.
Al
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 402 Guests (See full list)
