Need Some Help
i have a 2004 1500 4x2 with the 5.3...i'm having an issue with the DIC saying service brake booster soon..i had it checked everything was ok according to the mechanics, they had to update my computer? anyway i had the message flash again yesterday and after about 2 miles it went away by itself..what could have caused this? the break pedal seems to work ok not stiff....problem two, i checked my power steering today and it was down to the add line, i beleive it is factory fluid in it, i could not find any leaks, is there any explanation for this? and my last problem is what would you all recommend as far as brake fluid being flushed? mines a watery brown color with a weird odor, would this improve my breaking? it seems like i have to push the pedal down quite a ways to get any reaction from the brakes...thanks in advance
You didn't say how many miles on the truck or since the last break relining. Lower fluid is natural as pads/shoes wear. A full brake bleed would be warranted based on your description.
ALL power steering connections were dry?
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 716 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
