Replacing The Intermediate Steering Shaft
I'm going to replace my clunking intermediate steering shaft this weekend and just want to know if I really need the steeling wheel lock tool, or if just locking the steering wheel a bit after I take the key out is enough to prevent any damage to the clock spring?
No you don't need it. Some people tie them down. I had mine out twice, once to grease it and once to change it out. I also replaced the bearing as well and I didn't do anything to the steering wheel. I was just careful not to move it. I think you have to move it a good bit to screw up the clock spring.
If you remove the bolt with the wheel in the straight ahead position it won't move on you unless you move it. It's balanced to be straight up and down. If you have to move it around with the shaft un-installed don't go more then a half turn and go back to where you started.
    bellssn690
    bellssn690
  • Who's Online   5 Members, 1 Anonymous, 1,102 Guests (See full list)
